Results 1 to 4 of 4
    soxten's Avatar
    Mar 2013
    Default Audi A6 2012->> Clone Climacontroller
    I have a broken climacontroller from Audi A6 2012 with nec D70F3634
    I connect it with Smoke Multiprog by Uart and it say secure....
    Is it possible to clone this mcu in any way?
    Or is the best solution to desolder mcu and move to a used unit?
    4G0820043AC
    Skickat från min iPhone med Tapatalk
    Nov 2009
    secured mcu not possibile
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
    Jul 2016
    just install the used one and remove component protection (abritus can do some models) if no you can do it by ODIS online; no need to remove MCU
  4. The Following User Says Thank You to Drdiag For This Useful Post:
    immokill (28th November, 2019)
    soxten's Avatar
    Mar 2013
    I need to fix this, does it work by desolder and solder it back to used?
