Results 1 to 14 of 14
    May 2011
    Default 2016 mazda 6 milleage change, what chip and is it hard?
    hi all
    i got asked about changing milleage on a 2016 mazda 6
    just wondering if its an easy chip to read and easy to get to the chip
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    This car done by OBD by Mazdameter, X100 and etc. No need to remove dashboard.
  3. The Following User Says Thank You to Inquizit0r For This Useful Post:
    GameTheoryOptimal (25th July, 2018)
    May 2011
    hi Inquiz
    i do have an x100 thats afew years old
    will this work
    any chance it might stuff it up
    what if car is 2017 mazda as ive had some new cars be late 16 but really they are 2017
    thanks for the info
    letalcrudo's Avatar
    Nov 2015
    Canada
    x100pro goes fine on this cars by obd. just select "automatical detection" on the menu and follow the instructions
  6. The Following User Says Thank You to letalcrudo For This Useful Post:
    May 2011
    i only got an x100 noit a pro
    might invest in one
    whiuch is best one to get
  8. #6
    May 2011
    hey letal
    do u mean x100 pro by odbstar or the xtool one
    i really need to buy the correct tool asap to sort this mazda out
  9. #7
    Jul 2014
    Chile
    obdstar x-100 pro fast and easy
    fast and easy
  10. The Following User Says Thank You to mecanicaina For This Useful Post:
  11. #8
    ascrap2003's Avatar
    Sep 2016
    Texas
    Being ford is in mazdas bloodline i would imagine at least 2-3 more mileage locations like newer fords, but maybe I'm wrong but what if im right?
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  12. The Following User Says Thank You to ascrap2003 For This Useful Post:
  13. #9
    May 2011
    thanks guys
    i tried my old x100 and it couldnt do it so ive ordered an x100 pro from obdstar
  14. #10
    GameTheoryOptimal's Avatar
    Jun 2016
    Canada
    Quote Originally Posted by ascrap2003 View Post
    yes there is now a few places where they hide some more of those value.
    TPMS system is just one of them.
    you need mazda IDS to take a look at what they can find. (if it is important to you to do it properly)
  15. The Following User Says Thank You to GameTheoryOptimal For This Useful Post:
    ascrap2003 (29th July, 2018)
  16. #11
    May 2011
    just upgraded the tool and half the cars were not selected
    went back in and selected the cars and now it has mazda
  17. #12
    May 2011
    hi all still having issues with this x100 pro
    upgraded unit so now I have mazda
    I goto auto detection
    says turn ign on
    then says turn ign off and then back on
    tool is not connecting to the cluster
    what I did find is the car is a 2017 mazda 6 atenza
    so im wondering if the x100 pro will not do this model
    when I google it I find the x100 pro can do 2015 mazda 6
    or do I need to turn off and on a certain way cause the x100 pro just wont communicate with cluster
    any help to get this car sorted is greatly appreciated
  18. #13
    Aug 2015
    try this !
    when it first asks you to turn ignition off and on don’t turn it off just leave it on to read the mileage
    after you input desired mileage it then asks to turn off and on so you need to turn it off and on very quickly
    do this and it will work 100%
    Thos
  19. #14
    May 2011
    hi Thos
    pretty sure i tried that afew times
    just goes thru the 2 minute countdown trying to connect and then eventually says no connection
    and says to make sure ign is on
    but ill give it a try again
    thanks for the sugestion
