Results 1 to 4 of 4
    Jan 2014
    Compiegne
    Default FVDI kill my BSI Johnson Control for 308 Peugeot
    Please help me,
    I need flash for my BSI,
    FVDI kill
    n° 96 668 957 80 02
    BSI04EV KO5-00 041010
    BOOT: 2097777-1
    HARD: 212546801
    Thanks in advance
    Apr 2016
    holland
    as you can try to read pin again and meaby it go out off bootmode putt some powersuply to car ore otherewise flash is damaged you can find on this forum the right software and use ecu flasher with fvdi and choose jc control bsi
  3. The Following User Says Thank You to schouten1977 For This Useful Post:
    intervox (6th July, 2018)
    Sep 2014
    Read id with fvdi , check software signature. Don't try to write flash without knowing software signature, you will get into deep trouble. I gone thru this mess, almost cause me an heart attack.
    Regards,
  5. The Following User Says Thank You to malguy For This Useful Post:
  6. #4
    morfej's Avatar
    Dec 2008
    Repeat reading of the flash with ECU Flasher, to get the flash that's currently inside your BSI. As malguy said, don't play with software with different signature, as eeprom will be erased.
    Check your hardisk as FVDI makes backups during PIN reading ... and u might find your flash already there, but might be corrupted as well.
  7. The Following User Says Thank You to morfej For This Useful Post:
