problems a6 2.0 BRE 2006. Trembled at startup
Results 1 to 4 of 4
    Feb 2018
    Default problems a6 2.0 BRE 2006. Trembled at startup
    I greet you. I have a problem with the Audi A6 2.0tdi BRE 2006 ... the problem is that as soon as I start the car, for 2 seconds it has a trembling after which it calms. the same thing happens if the climate is on and I stop it ... for 2-3 seconds. in deceleration the same, small shocks below 2k rpm. the injectors are ok, the distribution OK, errors on the Vcds I do not ... an opinion please
    Feb 2018
    nobody????
    nil's Avatar
    Polska
    Helo
    Check the fuel filter with a thermal valve and a tandem pump.
    Feb 2013
    look inyector adjustment or camshaft wear.
