BMW e39 530DA dde/ecu messed up?
Results 1 to 5 of 5
    Jun 2018
    Post BMW e39 530DA dde/ecu messed up?
    Hello everyone! First of all, I'm fairly new to this whole ECU/flashing scene so bare with me
    Long story short: I got a bmw e39 530da and flashing with winkfp failed. Now I can't read codes on ecu nor EWS and the car doesn't start. After googling for days, I got to the point I was able to read the DDE in bench using Galletto 1260 and got the .bin dump file.. I've tried to reflash with winkfp but it doesn't work with any possible configuration.
    How should I proceed with this problem of mine? Can I reflash the ecu using Galletto 1260? What kind of file do I need?
    Any help would be appreciated and if (and when) you need ecu serial, software number, galletto dump or anything, I'll post them ASAP ^^ Help a brother out, I'm lost AF right now.
    Cheers!
    Jun 2018
    I was able to find some info about my ECU, couldn't get a full dump tho
    BMW HW 7789376
    Bosch HW 0281 010 314
    Assembly/SW number 778963
    Anyone got original file for this with automatic gearbox? Do you need more numbers? Does anyone have virgin file? Thx in advance
    Germany
    Post you OBD readout!
    Greets MR...
  4. The Following User Says Thank You to brobble For This Useful Post:
    laazeri (13th July, 2018)
    Jun 2018
    Thx for the reply! Here is my dump, read with Galletto 1260
    Germany
    Flash this into your ecu and it should be alive again. This is a full readout of an ecu with same bosch and software number. But I dont know, whether it is automatic or not. But itīs E39 3.0D. But I copied your AIF from your readout to ecu. So just reflash it with winkfp again and it should have the correct software.
    Good luck.
    Greets MR...
  7. The Following User Says Thank You to brobble For This Useful Post:
