Results 1 to 8 of 8
    Oct 2016
    Default Audi A6 2.0TDI 140HP 03G906016GB
    Hello
    Audi A6 C6 2.0 TDI 2007
    I have problem can`t connect to ecu with vcds or delphi on obd2 port
    i can read and write ecu with MPPS and see there are errors on car
    how can i get fix this ?
    I check fuses i try remove batery and hold 10 sec plus minus
    antwnhszr's Avatar
    macedonia is greek....
    Quote Originally Posted by nikte View Post
    Hello
    Dont get like that risk on OBD... read in BDM or bootmode
    Στάλθηκε από το SM-J320FN μου χρησιμοποιώντας Tapatalk
    rafal's Avatar
    UK - PL
    can you diag rest of modules?
    need help
    now my goal is to buy xp-005
    who will help?
    Oct 2016
    No i can`t connect to abs instruments ... nothing only mpps will read ecu
    dominik.m's Avatar
    Jun 2009
    POLAND
    Problem is from cangateway maybe?
    Oct 2016
    Can you explain this a little better
    Quote Originally Posted by dominik.m View Post
    Look under glove compartment there is gateway. Check that is in good condition and there is no water
    Oct 2016
    I check gateway and it`s looks ok
    I don`t understand how can i read ecu and errors with Mpps ( see image on post 1 ) and can`t connect with vcds or deplhi
    I really need to diagnose that engine.
