Bet she does not know ..( being in the sales dept..) and has to ask ........
It's inside the DP program in the tablet
thanks ,
still need to know How to get log files
and is it right ?
local/device\app\etc.
Pls check the attached instruction.
Log file will get to the background system and can be checked with your SN number.
Key Master DP Standard version.
Cannot find the "ODOMETER Correction" option anywhere?! Did anyone have similar issue?
Please help me
sorry , I told you I checked in
Home\DP\s.n folder\log
It is many log files.
and it is not in English language. and not range by time and date.
so my question , is how can I find my request file.
thanks anyway
SMP7@ How to know if tool full version with C package?
I ve ordered one and need to check.
X300 DP Plus C Configuration?
- Includes Below:
Immobilizer+Mileage correction+Diagnosis+Special function (Oil rest +ABS+Battery matching+ECU programming+EPB+Throttle programming+Airbag rest+TPMS+Steering angle rest+OBDII+DPF+Injector code+Supension matching+Gear learning+CVT learning+EEPROM+Key renewing+ECU cloning)Adapter(P001 programmer+C001 circuit board+C002 circuit board+W001 data cable+W002 data cable+W003 data cable+Toyota smarkt key Emulator)+others(Ignition coil+Remote tester)
dont listen to him
http://www.digital-kaos.co.uk/forums...=1#post3280183
go there do that
hcip (28th August, 2018)
click this attachment
you need to go into the DP program
NOT INTO THE FILES
go to the report center in the DP program
select all of the files and send them all
then contact them through skype or whatsapp and give them your serial so they can retrieve your log files from the server and look into it
is posible ford transit 2016 km calibration with x300 dp plus
thnx
