Page 17 of 44 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 658
  1. #241
    Jul 2018
    HELLO I have OBDSTAR F100 if anyone there make key of ford fucus 2015 OR KUGA WITH OBDSTAR F100
  2. #242
    Jul 2018
    I Already Make KEY To Ford Transit 2014 But Buy OBDSTAR F100 In Two Minute
  3. #243
    Apr 2018
    Quote Originally Posted by castin View Post
    Yes, add Prox key.
    what did the device display when failed?
  4. #244
    Jul 2018
    Quote Originally Posted by djollie View Post
    NISSAN QASHQUAI 2015 PIN AND PROXY KEY SUCCESSFUL
    BY Whish Tool exactly
  5. #245
    rob h's Avatar
    May 2011
    What series Transit, with tibbe key, or hu101?
    Quote Originally Posted by Anass GM View Post
  6. #246
    Jul 2018
    Quote Originally Posted by rob h View Post
  7. #247
    rob h's Avatar
    May 2011
    This is a 2006-2014.
    Simply writing 2014, could be interpreted that the 2014-2016 could be done.
  8. #248
    Feb 2018
    España
    Add key or all key lost?
  9. #249
    Jul 2018
    Quote Originally Posted by TukoSalamanca2 View Post
    both of them
  10. #250
    X300 Pad full ,
    Failed to reset Immo Toyota Corolla 2015 H type
    tried both USA , Middle east.
  11. #251
    Jan 2017
    USA ����
    Quote Originally Posted by m-o-y View Post
    X300 Pad full ,
    ok what is your location and what was the origin of the car?
    all keys lost?
    bought from salvage?
    do you have a vin? can you share the first 3-4 numbers? NOT THE WHOLE THING!!!!!!!!!!
  12. #252
    Location Sudan
    car specifications : Middle East.
  13. #253
    Dec 2017
    RE: the screen issue. Got my new screen today and fitted it and it's back up and running. (got my first replacement a few weeks ago but someone must had opened the bubble wrap with a stanley knife somewhere in transit as one of the cables was sheared off... I'm 99% sure it wasn't me...
    Thanks to Vivian @ OBDSTAR and Tradelocks who were very helpful.
    Here's the video should it be helpful to anyone else. It's not 100% step by step, but it's pretty close
    (my attempt took around 4-5 times longer and contained many's a swear word)
  14. The Following 3 Users Say Thank You to finakeys For This Useful Post:
    Brof (17th November, 2018), PocketHero (17th November, 2018), rob h (19th November, 2018)
  15. #254
    Hampshire
    I have changed a lcd+touch+the main pcb before, its quite easy taking them apart and change. however one word of advice to all, do not use a charger more than 6Volts, and never connect to a 6V car charger, yesterday, I connected my x300 with the new pcb to a 1.5 Amp 12V to multi voltage select car charger, Centre pin + and 4.5 volt was selected, but it wouldn't charge, then I connected to my home charger, guess what, the xdp300 doesn't show charge and the green light stays on all the time, even when device is turned off, after a while I checked the battery level, and luckily it had taken some charge, unfortunately this device has zero protection against power input, you have been warned.
  16. #255
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by nazz2 View Post
    if you already disassembled put a 5.1V/3-5A Zener to the charging line and you will be fine
