weird as hell
sorry i dont know alot about what cars you guys got down in the oz and what systems they have
they are super close to you tho youd think theyd have the same stuff or something
With the H100 I've got the door locks do not cycle on any car I've tried.
I have updated firmware many times & run whatever version is the latest.
I want to see this programmer work just one time.
Same with the F101 I've got, never worked except to add a key on a Hilux which I could have done manually anyway because I had a master key or used techstream same thing
So if either of these programmers don't work, should I buy one of their tablets for over $1000usd?
weird as hell
The thanks button is HERE looks like this --->>> THANKS
Vauxhall Mokka 2016 all keys lost and pin extraction from BCM successful...incidentally smok could not extract pin
Obdstar x300DP failed in the programming of an FEM module of a BMW F20, the issue is that the key was programmed when the remote control but I could not start either with the original key or with the copy.
Has anyone had the same problem? Does OBDSTAR not have the configuration to restore the car? I could not solve it and I had to send it to the official service.
About the Fem, Select; code data backup
After writing this back, it runs.
NISSAN QASHQUAI 2015 PIN AND PROXY KEY SUCCESSFUL
how to update X100
I have x300dp with immo packet. Is possible update with mileage?
Dacia Sandero 2014 all keys lost success
Brof (26th October, 2018)
