mbz S class w220 eis
Results 1 to 12 of 12
    dd1's Avatar
    Aug 2014
    Default mbz S class w220 eis
    Hi everyone, i was trying to make a key for a 2005 mbz s class w220, i have read the mcu, 1L85D, with r270, and it showed the mileage and vin also normal, i made a key. Now the new key wont function, the old key wont function either. The original key started car no problem, the only thing is that they wanted an extra key. The eis is A2155450808. Can you guys help me????????? Thnx in advance
    rob h's Avatar
    May 2011
    Does the old remote still work?
    Check the 7.5 amp fuse, on the right side of Dash.
    dd1's Avatar
    Aug 2014
    The old key wont work
    dd1's Avatar
    Aug 2014
    And I have checked the pwr and ground on the plug ok
    p1et's Avatar
    Oct 2013
    Probably damaged flash. Find same part number EIS flash and upload it to your unit
    dd1's Avatar
    Aug 2014
    But I had read the eep only!!!!!
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by dd1 View Post
    Post the eep file, let's take a gander.
    p1et's Avatar
    Oct 2013
    It doesn't matter, flash might corrupt when you read eeprom and you should know that doing such job. And stop shouting, this is ridicolous.
    Aug 2015
    North America
    Here's the flash. Post the eep so we can take a look. Unless it's a State Secret, that is.
  10. The Following User Says Thank You to droidwayne65 For This Useful Post:
    dd1 (3rd August, 2018)
  11. #10
    dd1's Avatar
    Aug 2014
    thanks droidwayne65, always there for us. he is my hero. i got another eis and all went ok. thank you guys
  12. #11
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by droidwayne65 View Post
    hi everyone, so this is the strange thing. when i hook up another charger or good battery on the car, next to the original, it starts every time. without it, it gives issues. what gives?????
  13. #12
    i think that we need to start working 4 u.
    all i read from you is help..............
