Hi.
I bought a Renault COM interface because I suspected I have some problems with my car and I wanted to know how serious they are. It is a clone hardware from China. It came with Superscan software. I installed it but it is old version. It works anyway. I wanted to check DPF filter if it is clogged and how often it regenerates because I felt it is too often regenerating every 300-400km running on highway. If I was running these kilometeres in the city would be normal but in highway doesn't seem normal to me. After I tried to disable hill start assist and it appeared an error on board. Don't know if it is just coincidence or Renault COM has something to do with it.
I got error P0638- throttle body actuator performance.
I delete this error but after short while it reappears. Strange part is that after I delete error and I run my car at full throttle I had a problem with engine power. It seems I lost turbine that low power I got. After turning off engine and restarting it seems engine runs ok but I have error present on board. I wonder if this interface gives same error as Renault CLIP because I suspect clip would lead me closer to my problem.
My car:
Renault Clio IV 1.5 dci 75hp
I tried to calibrate throttle by pressing full throttle with ignition on , then off.
