Results 1 to 7 of 7
Thread: Peugeot 108
    Sep 2013
    Default Peugeot 108
    Friends what toll can make key for Peugeot 108 2017 on id 74 ? I found some similarity to Toyota Aygo but on MVP i got only 2015 proximity. Can some share experience.Thanks
    Apr 2017
    You can att key if you have working key with Mvp Zedfull or smart pro its H chip 128 bits chip you can use LKP and original
    remote its Manuel programming
    Moes
    Verzonden vanaf mijn iPhone met Tapatalk
  3. The Following User Says Thank You to mustafabahar For This Useful Post:
    holbi1 (12th July, 2018)
    Sep 2013
    Have you try with MVP friend ?
    rob h's Avatar
    May 2011
    All Keys lost, then you Will need to replace the immobox.
    A seconhand box, with atleast a master transponder Will do.
    Adding a transponder, obdstar , skp900
  6. The Following User Says Thank You to rob h For This Useful Post:
    Jun 2016
    Quote Originally Posted by holbi1 View Post
    obdstar F108+ is okay.
  8. The Following User Says Thank You to crazylou2017 For This Useful Post:
    holbi1 (14th July, 2018)
  9. #6
    koln, germany
    Quote Originally Posted by crazylou2017 View Post
    NO IT's for psa 108 IS A TOYOTA
  10. #7
    rob h's Avatar
    May 2011
    Is this akl,
    if not, check if org key is master.
    Then add key using techstream.
    There is a F101 toyota obdstar, not sure if it does h-type.
    And Tango, they can clone these H 128, sinces latest update. (payable option)
    First in the World Copying Toyota H-key Blade (128bit) on LKP-04 *
