Did you try new eeprom ?
- 3 weeks ago I cleared the crash for 98820 9NG4A vis Car Pro Tool Air Bag Service software and everything worked just fine.
- I went to "diag" mode on my scanner to make sure that all SRS components are OK, all checked out OK.
- 2 days ago my friend called me to tell me that SRS Light is ON again (solid, not flashing)
- I connected the scanner to see B1418 "Control Module" fault
- Took out the Module, re-flashed -> same result
- Loaded the Original file into EEPROM -> same result
Did any of you guys ran into the same issue on any Infinity or Nissans and what could be the cause of this??
Thank you!!
Best regards.
Dragon
slavax (13th July, 2018)
Replaced with a new EEPROM, re-programmed and...voilà it communicates and works well again.
Thank you guys, topic closed.
