    Aug 2015
    Default Vw mib 1 panasonic
    I need to change mib1 panasonic unit i saw there is a eeprom in it, is it possible to swap it, that component protection and navlock will not get active??
    Jul 2018
    Quote Originally Posted by offsystem View Post
    if you are going to swap headunit from another car there is a problem called component protection. You need to remove it. First way is official, in car service by online diag. Second way is to find "hacker" (there are few persons which can do that).
    both ways will remove all activated functions, i mean navigation, bluetooh, carplay...
    hacker can activate them back
    Junior Member Olsak's Avatar
    Jun 2018
    A
    solution? thanks
    Aug 2010
    Solution for MIB1 STD ZR ? CP+activation map ?
    Feb 2019
    No solution for Panasonic units.
    Best way is to swap to some MIB2 unit
    MIB 1/2 Solution
    CP-OFF, Activation CarPlay Android auto map care, US/EU conversion
    WhatTheFec, Advanced Green Menu
  6. The Following User Says Thank You to punkforever For This Useful Post:
    baleyba (25th July, 2020)
    still no solution?
