Results 1 to 5 of 5
    Jul 2018
    Default How to change parameters in the Engine ECU
    in the BSI, but when I try to change the parameters in the Engine ECU it doesn't work
    The option is there, but if I click in "Present" nothing happens
    Is this a limitation of the car ECU or Diagbox
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Bro this is very easy, go to "ecu present" and depending on the car activate all the calculators that are present in the car, This happen when you put other bsi or virgin bsi.
    Jul 2018
    Thank you
    I choose activate nothing happens.
    Diagbox 7.83
    Jul 2018
    You can see the pictures
    Can not activate
    Jul 2018
    Can help me
