Hobbyist - R270 "Send Command wait"
Results 1 to 5 of 5
    Jun 2018
    Default Hobbyist - R270 "Send Command wait"
    I am trying to get a EEPROM dump from a 0L15Y CAS3+ from a 2008 BMW 5er. This is from a Junkyard so if I mess it up it will not matter. I am just doing this as a DIY activity. When I hit read it will just sit at "Send Command wait". I am assuming something is not hooked up right but I am not sure what is. I have version 1.20 of the software running on a Windows XP laptop. This is a R270 from Aliexpress.
    IMG_20180714_170703.jpgIMG_20180714_170936.jpgIMG_20180714_170940.jpgIMG_20180714_170944.jpgIMG_20180714_141629.jpg
    http://blog.eobdtool.co.uk/wp-conten...S3_0L15Y-3.jpg
    Anyone have any ideas?
    Jan 2017
    USA ����
    ahhhh i see
    your problem is you are bad at taking pictures!
    hhahahahahaha
    seriously tho the close ups of all black wires is so not helpful
    Jan 2017
    USA ����
    the points look correct
    i cant tell if the correct wire is going to the correct place because they are all black tho
    http://www.digital-kaos.co.uk/forums...as3-mask-0L15Y
    Jun 2018
    Quote Originally Posted by sleepyrz View Post
    All of the solder points are bang on from the guides. I went off wire numbers 1,5,7,8,19,24,26 starting with the wires with the 1 label on it. All of the wires I can tug on them without them ripping out.
    Feb 2018
    Glasgow area
    Do you know the cas version?
    I was been unable to read a CAS3+ IstaP with R270.
