smok read for obd in 1min
Read error Bsi Valeo 73006212,con micro Nec 75076303 I can not read this if it is from a Berlingo I have the programmer nec programmer I can not read it I put pictures but I get this error: lines(s): 12 must be disconnected from external circuit.
I have lifted pin 12 I put pin 12 on the end resistance and I can not read the mic. Does anyone have a solution?
Why you want to read?
I do not have a smok tool, I only have nec programmer.
I want to read because I want to put the kilometers to 0 because it is 999999.
https://sterowniki.co/?17,adapter-pr...ogramatora-etl
tray this adapter I have and it works ok
in circuit I can not read the mic
amlop (15th July, 2018)
ok thanks friends.
