albonidao (11th February, 2019), boxsport (13th May, 2020), Col19 (23rd February, 2021), jo?o antonio (6th July, 2014), shtyrya2 (6th May, 2014)
This is excelent program for st10,infineon and micronas mcu. It works with max 232 interface but need to be cracked.It can also program eprom thru flash. Program FLASHit here HSE-Electronics the competence in embedded systems, C166- and CAN-Application.
In this post is the flashit, with its "crack"
http://www.digital-kaos.co.uk/forums...-9-full-62952/
Thanks for the info!
El Cordobe!
RASCH MotorSport
Here (is "live" again)
http://www.st.com/mcu/files/mcu/1158679843.zip
El Cordobe!
RASCH MotorSport
Hi, I'm looking for an interface for st10f275 microcontroller that is implemented in an ECU. I'm trying to read/write in the flash.
hello
i am carlos arenas from mexico city
this RS232 to K Line interface realy works ?
[QUOTE = Mac Gyver; 426157] esta interface RS232 a K Line trabalha com software ST10FLASHER:
ECU para PC[/ Quote]
Hello friend, with this scheme I can read ecu with ST10, for example 4SF?
hello friends! which is the correct interface to run the software?
someone honest?
hola cordobes ! fabricaste la interface ? funca? vos tenes la info para conectarla a las diferentes ecu ?
Hey guys, argentinos incluidos. As a general rule of thumb you can access st10 through k line putting pol04 to mass and pol05 +5v. do it through 100ohm resistors. x-progM is suggested.
So look for those pins in the appropriate st datasheet!
Regards...
as requested by marcio1758 because the previous link is dead:
ADEL.KSHLAF (26th April, 2023), albonidao (11th February, 2019), angmar (27th February, 2019), boxsport (13th May, 2020), Col19 (23rd February, 2021), nicogaragearg (19th August, 2023), redful (20th June, 2019), sasa5 (18th May, 2016), shtyrya2 (6th May, 2014)
Hola amigo Diego, yo soy de Chile ,
Grande messi
queria ver si me puedes ayudar con el tema de tratar de leer y escribir en la st10f280 que trae la ecu del siena 4sf.cs.
Por este link sale manual de bootsstarp que no entiendo para que es, lei que tu se?alas que se puede leer con xprog -m que yo tenbgo, buscando en el menu sale la conexion pero no la entiendo, no se donde pinzar en la ecu???'
me puedes ayudar ???
saludos
Grande messi
saludos
Hola Diego che guevara, queria ver si me puedes ayudar a leer con el xprog m una ecu de siena 4fs.cs que trae st10f280. No entiendo el dibujo que trae el xprog, no se donde pinzar en la ecu???
necesito matarle el immo pq ese auto trae esa maldita mascara 1k59h o algo asi que solo lee la omega y genara la tango , maquinas que no tengo por lo costosas.
saludos
pd: para que es el manual de bootstarp brasilero que postearon mas arriba???'
hola,
no he podido encontrar de donde bajar el st flasher, alguno lo tiene y lo puede subir en algun file server.
I couldn't find st flasher soft. does anyone have it and upload it into any file server
couldn't find st flasher do you have it?
