none of the links for download does not work.can someone upload it please
br
br
ADEL.KSHLAF (26th April, 2023), Adi202 (21st October, 2015), adibadi (13th September, 2014), albonidao (11th February, 2019), alefabi2006 (10th May, 2014), boxsport (13th May, 2020), Col19 (23rd February, 2021), cruzpablo (7th December, 2021), Darek90 (3rd September, 2022), doohaarama (16th November, 2015), eagleone-two (10th January, 2015), electronicdeivi (15th March, 2024), eudin77 (4th January, 2015), filaalfa28 (1st March, 2019), Freshele (6th July, 2020), frigo (24th December, 2014), gameiruz (23rd April, 2018), gizmo666 (17th November, 2013), jcoli (3rd March, 2020), jo?o antonio (6th July, 2014), julo45 (6th November, 2014), lokher (20th September, 2016), lordraidem (3rd March, 2023), manny911 (14th February, 2017), mayer2 (8th April, 2020), mchelli (9th February, 2021), mijatx (24th January, 2015), mipmf (13th January, 2016), nicogaragearg (19th August, 2023), pablobonome (9th February, 2016), reda75 (6th November, 2022), redful (26th June, 2019), rybenz (24th December, 2021), sasa5 (18th May, 2016), shanektm450 (26th September, 2017), shtyrya2 (6th May, 2014)
Thank you very much for the info
Guys, i have original flash of ST10F280 in ST10Flasher tool format 1*474*724 bytes.
How can i export flash from it?
It must be 524288 bytes.
So, is it possible to use a VAG-COM KKL cable with the ST flasher? In this case, do we need to modify anything?
Hi, I'm looking for an interface for st10f275 microcontroller that is implemented in an ECU. I'm trying to read/write in the flash.
Check this Anbindung an FLASHit
ZYX (25th September, 2013)
hi friends, i have proble for reaf ecu 5sf8 with st10flasher
ecu ha ST10F296
i use interface obd
com OK
monitor ok
but when i read dump error
*Dump-->ERROR
Description: LoadExternalFlashMonitor: target Not found
but if i read dump SCREEN SELECTION is ok
if i read with TXT and not with HEX is OK
please help
I'm having a problem with ST10 Flasher 2.4B , I get this message:
I'm using a real COM port laptop, but I'm looking for a circuit version that works with USB, anyone?
Inpa Ediabas OBD2 Interface Ediabas OBDII Interface for BM-W
COM ,FULL ST10F.
