Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
  1. #31
    Top Poster automan's Avatar
    Jun 2010
    serbia
    none of the links for download does not work.can someone upload it please
    br
  2. #32
    autoelite's Avatar
    hi, i have it.
  3. The Following 38 Users Say Thank You to autoelite For This Useful Post:
    ADEL.KSHLAF (26th April, 2023), Adi202 (21st October, 2015), adibadi (13th September, 2014), albonidao (11th February, 2019), alefabi2006 (10th May, 2014), boxsport (13th May, 2020), Col19 (23rd February, 2021), cruzpablo (7th December, 2021), Darek90 (3rd September, 2022), doohaarama (16th November, 2015), eagleone-two (10th January, 2015), electronicdeivi (13th April, 2024), eudin77 (4th January, 2015), filaalfa28 (1st March, 2019), Freshele (6th July, 2020), frigo (24th December, 2014), gameiruz (23rd April, 2018), gizmo666 (17th November, 2013), jcoli (3rd March, 2020), jo?o antonio (6th July, 2014), julo45 (6th November, 2014), lokher (20th September, 2016), lordraidem (3rd March, 2023), manny911 (14th February, 2017), mayer2 (8th April, 2020), mchelli (9th February, 2021), mijatx (24th January, 2015), milerk (19th April, 2024), mipmf (13th January, 2016), nicogaragearg (19th August, 2023), pablobonome (9th February, 2016), reda75 (6th November, 2022), redful (26th June, 2019), rybenz (24th December, 2021), sasa5 (18th May, 2016), shanektm450 (26th September, 2017), shtyrya2 (6th May, 2014)
  4. #33
    jarripote's Avatar
    Apr 2010
    Thank you very much for the info
  5. #34
    Mulatre's Avatar
    Feb 2010
    Ukraine
    Guys, i have original flash of ST10F280 in ST10Flasher tool format 1*474*724 bytes.
    How can i export flash from it?
    It must be 524288 bytes.
  6. #35
    dimitar's Avatar
    Quote Originally Posted by Mulatre View Post
    Read the datasheet you will see the flash location
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  7. #36
    Jul 2010
    So, is it possible to use a VAG-COM KKL cable with the ST flasher? In this case, do we need to modify anything?
  8. #37
    Sep 2009
    Quote Originally Posted by evgeniyy View Post
    You need it?
    Thank you!!!!!
  9. #38
    Jul 2010
    Default KL Simple
    Quote Originally Posted by autoelite View Post
    hi, i have it.
    Hello, I built the KL Simple from the diagram above but it didn't work...do we need any drivers or just the regular Windows com port driver?
  10. #39
    Apr 2010
    Hi, I'm looking for an interface for st10f275 microcontroller that is implemented in an ECU. I'm trying to read/write in the flash.
  11. #40
    dimitar's Avatar
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  12. The Following User Says Thank You to dimitar For This Useful Post:
    ZYX (25th September, 2013)
  13. #41
    Jan 2012
    Quote Originally Posted by dimitar View Post
    Hy , this work with Flashit? tested , i need to read write st10f269
  14. #42
    tatop's Avatar
    Dec 2010
    italy
    Default st10flasher 2.3C problem for read st10f296
    hi friends, i have proble for reaf ecu 5sf8 with st10flasher
    ecu ha ST10F296
    i use interface obd
    com OK
    monitor ok
    but when i read dump error
    *Dump-->ERROR
    Description: LoadExternalFlashMonitor: target Not found
    but if i read dump SCREEN SELECTION is ok
    if i read with TXT and not with HEX is OK
    please help
  15. #43
    Jul 2010
    Default ST10 problem with Monitor
    I'm having a problem with ST10 Flasher 2.4B , I get this message:
    I'm using a real COM port laptop, but I'm looking for a circuit version that works with USB, anyone?
  16. #44
    argentina
    Quote Originally Posted by brchip View Post
    yu can solved your problema, i hve same problema, can you help mi?
  17. #45
    EARTH
    Default USE Inpa Ediabas
    Inpa Ediabas OBD2 Interface Ediabas OBDII Interface for BM-W
    COM ,FULL ST10F.
  18. The Following User Says Thank You to datapage For This Useful Post:
