Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
    Jun 2009
    Default Interface ST10Flasher
    Please, someone has the layout of the interface ST10flasher via K-LINE.
    You need it?
  3. The Following 15 Users Say Thank You to evgeniyy For This Useful Post:
    ADEL.KSHLAF (26th April, 2023), albonidao (11th February, 2019), blackground (12th August, 2021), Col19 (23rd February, 2021), eudin77 (4th January, 2015), fenix5 (11th December, 2013), n599fbm (26th June, 2014), nicogaragearg (6th August, 2023), NORSHAN (2nd May, 2014), paulocesar (21st October, 2016), PEDRO4053 (31st December, 2017), realcom (19th December, 2017), redful (20th June, 2019), rybenz (24th December, 2021), saheta (10th February, 2021)
    Jun 2009
    Quote Originally Posted by evgeniyy View Post
    You need it?
    This is not used for TX and RX, the right has only LINE-K turned on OBD2.
    Thanks for responding.
    Top Poster Cordobe1's Avatar
    Argentina
    Hi everyone,
    Would have the schematic for the USB?
    El Cordobe!
    RASCH MotorSport
    use the Kline of VAG KKL cable, the software ST10FLASHER recognizes the K line of this cable.
    is necessary to connect resistors in some pins of the ST10Fxxx microcontroller for him to stay in bootloader mode.
    argentina
    Default st10
    can any body share st10flasher for obd? an in wich pin need put a resistance for bootloaders mode ?
    Argentina
    Quote Originally Posted by monini64 View Post
    The soft is here : http://www.digital-kaos.co.uk/forums...tool-v2.4b.rar
    Say tnks to gezame
    The pin is different for each ECU, you have to find the pin for each .-
    El Cordobe!
    RASCH MotorSport
  9. The Following User Says Thank You to Cordobe1 For This Useful Post:
  10. #8
    Argentina
    Quote Originally Posted by Mac Gyver View Post
    Thank you very much for helping!
    Can I use VAG COM (Chine Clone)? It is necessary to connect +12 & Ground?
    El Cordobe!
    RASCH MotorSport
  11. #9
    argentina
    this link dont work
    no funka cordobe
  12. #10
    Argentina
    this link dont work
    no funka cordobe
    Hola Monini64,
    Puse ese Link para no sacarle los creditos a Gesame, que muy gentilmente subio el soft.-
    Aca esta subido a Rapid por Mi RapidShare: 1-CLICK Web hosting - Easy Filehosting
    I put the link to not steal the credits that are "Gesame", ever so gently ascended the soft .-
    Here is uploaded to RapidShare for me
    El Cordobe!
    RASCH MotorSport
  13. The Following User Says Thank You to Cordobe1 For This Useful Post:
    pablobonome (9th February, 2016)
  14. #11
    thanks cordobe.
    Muchas gracias cordobe.
    Regards.
  15. The Following User Says Thank You to gezame For This Useful Post:
    boxsport (13th May, 2020)
  16. #12
    Where can i download this software?
  17. #13
    http://www.racechips.com.br/arquivos/BOOTSTRAPS_4SF.pdf
    a manual in brazilian portuguese on how to connect the resistors on ECU board to let the st10fxxx microcontroller in bootmode.
  18. The Following User Says Thank You to Mac Gyver For This Useful Post:
    fethilid (8th December, 2015)
  19. #14
    this RS232 to K Line interface works with ST10FLASHER software:
    ECU to PC
  20. #15
    Russia/Moscow
  21. The Following User Says Thank You to AndyPP For This Useful Post:
    shtyrya2 (6th May, 2014)
