i got voltage on vpp all fine now
but when i try read MICRONAS 3217g its show JTAG ID does not match . Device ID: 0xfffffff
i have same problem did you solve yours ??
Hello to all. Upload good photo of pcb for more information, on which pin you are missing voltage, more info.
IF I HELPED YOU PRESS THE " T " BUTTON
Hello to all. What voltage do you have on pin1 of IRF7316 ( 8pin mosfet ), pin2 is control pin and pin 7,8 are output of transistor. When programmer needs VPP it will pull to low
pin2 and if you have voltage on pin1 it will pass to pin 7,8.
