Results 1 to 14 of 14
    Apr 2018
    Default Opel Astra H 1.7 CDTI 110hp
    what is a safe tool to read Astra H 1.7 CDTI 110 hp since kess has grey protocols on it?
    mancioks's Avatar
    Feb 2017
    Germany
    Quote Originally Posted by JTDperf View Post
    kess 5.017 china red pcb does it ok.
    Sep 2013
    garage
    if is denso ecu ....i use mpss to read and write ...and no problem
    Apr 2018
    I could acces mpps v12 but not sure if that reads all data.I dont wanna lose injectors code or other horror stories I heard.
    morfej's Avatar
    mpps v18.... V12 is too old.
    KESS can read eeprom as well, so it is a bit better concerning the "saftey".
  6. The Following User Says Thank You to morfej For This Useful Post:
    alclot (24th July, 2018)
    Apr 2018
    It seems like the ecu is EDC16c9 with no read by kess.
    Is it ok to get ID , download full BDM then write by OBD?
    mancioks's Avatar
    Feb 2017
    Germany
    Read/Write with mpps!!!
    Jul 2017
    I read and wrote edc16c9 a few times using kess china clone. every time without a problem
  10. #9
    Dec 2017
    Yes china Kess should be fine I’ve done a few so far Tanx to God no issues whatsoever
  11. #10
    mancioks's Avatar
    Feb 2017
    Germany
    Kess never read edc16c9. C39 ok, but c9 is only write.
  12. The Following User Says Thank You to mancioks For This Useful Post:
    kalisiux (24th July, 2018)
  13. #11
    Jul 2017
    Quote Originally Posted by mancioks View Post
    you're right. sorry for misleading. I read edc16c39. human memory can be unreliable
  14. #12
    Apr 2018
    Tried with kess and..
    WARNING
    an error occurred during the writing.
    I got this error during OBD and ecu bricked .
    Hope it can recover by BDM
    No recovery works by OBD since all of tries succed in same error.ID was ok
  15. #13
    mancioks's Avatar
    Feb 2017
    Germany
    It also can be recovered with SPS done with Tech2 or Mdi.
  16. The Following User Says Thank You to mancioks For This Useful Post:
    dus (5th October, 2018)
  17. #14
    Apr 2018
    No result even with BDM.File has checksum ok,but car does not start....this is horror ecu ...Does not even ID
