Results 1 to 7 of 7
    Dec 2016
    Poland
    Default VW Caddy adaptation new cluster from old cluster
    HI!
    I have VW Caddy with cluster without colling temperature I bought a new cluster also from caddy with cooling temperature.
    I opened both clusters
    on old one i have 24C32WQ EEPROM
    On new cluster i got 24C16W6 EEprom
    Both Eeproms are in atachment i want to coppy immo and pin from old one to new cluster so it is working.
    In addition in new cluster i need a 102 000 KM milage change.
    Can someone edit new cluster dump so it works in car?
    Will give rep and Thank.
    I can Pay.
    scv_15318210725724111247892863357441.jpgscv_15318210844451330715147598346469.jpgscv_15318211050334597360603087500879.jpg
    kuba
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
    Feb 2010
    In EEP
    Hi you can pay but this is obd2 job or xprogM in only Eeprom can't do it
  3. The Following User Says Thank You to vasa For This Useful Post:
    kubuswujo (18th July, 2018)
    Dec 2016
    Poland
    I have normal Xprog not XprogM
    how to do it via obd? What tool is needed?
    I have VCDS, VAS-PC, ODIS,CARPROG
    what tool to use to program new cluster VIA OBD.
    Oct 2014
    Netherlands
    Carprog looks good.
  6. The Following User Says Thank You to H2Deetoo For This Useful Post:
  7. #5
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Fvdi - Ok.........
    Press Thanks and Reputation
  8. The Following User Says Thank You to Kocta For This Useful Post:
  9. #6
    Dec 2016
    Poland
    Carprog but to read eeprom? I have read eeprom and what?
    Or carprog via obd somehow?
    hmn....
  10. #7
    Dec 2009
    Carprog via OBD should work. You need to read immodata from your old dash and transfer to "new" one.
