professional emulator only in this case, tested - https://www.youtube.com/watch?v=6VpcLVoCDy0
Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
PORSCHE / FERRARI / MASERATI - immobilizer solutions
VAG IMMO CALCULATOR SOFTWARE
rafap (18th July, 2018)
also immo disable in dump available ,but its not free
danielif (28th December, 2020)
I ize immo with this professional emulator in ecu sid208 all perfect
danielif (18th July, 2018)
Iīm interested for this emu. I have order this one. But I donīt see in the manual what I must make with unit. In other units is visualization what modify in ecu or emulator. How I can read PIN from unit, etc. My friend try read with ori ktag but without success.
Many thanks for help or kick right way. :-)
No adverts in sigs mate
The emulator is very simple to use ,only need get synchro bytes from ECU dump and store in 24C02 in emulator board, NOT need make any changes in ECU dump ! (y)
I upload software for this task also in sw(work on win7 or upper) have foto how solder emulator.
Emulator have very clear signalization about status - 3 LEDs green,red,yellow.
the emulator have one in the world unique function of checking the query and give info when query from ECU is not compatybile to synchro bytes stored in emulator 24C02 memory
arnou (28th August, 2019), atomantmk (30th November, 2019), AutoWOW (6th December, 2023), baltazar3 (12th October, 2020), Charlieb1 (11th May, 2021), CHIKODIAG (8th September, 2023), danielif (17th May, 2019), donesko (25th January, 2019), ecufix (30th September, 2020), esse (3rd April, 2020), Gery (19th November, 2019), HAMIZA (10th September, 2022), jenya (2nd October, 2022), Lainer (27th February, 2020), Le-Mans (1st November, 2019), line44 (19th October, 2023), MBGL (24th April, 2020), nizarben (24th October, 2019), padani1 (6th July, 2021), pepelazz (9th February, 2020), PETERALC506 (9th November, 2019), Ray6K (7th July, 2023), samir038466 (18th March, 2021), samir28 (10th May, 2019), tomushas (23rd February, 2021), Toutancamon (2nd April, 2021), volodin69 (3rd June, 2022), wojtech (23rd March, 2021)
@avital
Will clone ktag read ECU for me to get syncro bytes?
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
Upload read eeprom by ktag to my software and check.
If dump file is all right - the software will show synchro in format to emulator.
norman1967 (11th February, 2019)
I have tried to make immo for sid 208, only emulator or another start kit: key, bsi,ecu.
Hi Dears. Where can find this emulator for buy?
