Results 1 to 3 of 3
    May 2018
    Default 77960-scv-a012-m1 clearing crash data help
    Hi, I do most of this stuff with a TL866A, and from this .uds script, it seems that you just clear from 580 to 5EF. usually the crash data is longer than that from the handful of other ones I've done, so I just want to double check that that is the right part to clear. looking at my dump though, It seems like I should clear 570-57F as well
    [edit] here's the dump if you'd rather clear it yourself and let me compare clean to dirty. thanks!
    hudy26's Avatar
    May 2017
    Default ok
    test and give a report
  3. The Following User Says Thank You to hudy26 For This Useful Post:
    riverman (18th July, 2018)
    May 2018
    thanks, looks like my intuition was off! if I don't reply after this, it's because it worked.
