hello,
have you ever found a solution for this problem, i am dealing with the same problem at the moment
looking forward to hear from you
Hi. I have Passat B6 with faulty Elv. I have fault 02823 - Requirements for Locking the Steering Column Lock not met. ELV stay in unlock position. I buy new ELV from dealer and make adaptation. Car works but ELV wont lock. Have same fault 02823. I buy used Comfort module and write eeprom from ori unit, same thing. Did anyone have a similar situation
hello,
Did you check all wiring, not a problem there?
Also note that ELV drive power comes from SWCM as well, try to replace it just for testing.
heey
thanks you for tying to help!
the ELV has all its power and ground connection's as far as i can check
the power for the elv motor itself(1.5mm2 yellow/red wire) comming from the comfort module does a little strange
the comfort module power's it when i put the key in the slot and only for less then a sec. nothing happens when i pull the key out
i have(just to be sure) made a bypass for this connectien so it can not be a problem
the elv is unlocked car work's gread but client wants the lock to work...
is there something els to check before i change even more module to try
looking forward
It is normal for power from CCM or SWCM to be available for a short time.
SWCM controls unlock
CCM controls lock.
diagnostic80 (5th April, 2019)
again thanks for helping!
i found out that the client has OEM cruise control installed to his car
and needed a different SWCM, the numbers on the swcm tells me it is probably from a car without electronic steering lock
so i assume this is why the elv does not work
So SWCM it was
most likely! not 100% sure because the car is back to client, a new swcm was to expensive in his opinion
after all car run fine only the steering lock will not work
(typical ''it needs to be fixed no matter what'' and ''ow no that is way to expensive'' kind of tings)
i
H2Deetoo (5th April, 2019)
