Results 1 to 8 of 8
    Oct 2014
    Default help driving modes edc17c64
    hi all! could someone help me with driving modes on that ecu.
    I cant understand which maps change when selecting eco mode or sport, normal mode.
    i would like to let remap just on sport mode.
    I have tried throttle maps wirh no luck even nm to iq maps and same, maybe lambda maps?
    here i let you my .ols maybe cpuld be usefull for someone
    could someone take a look if i forget some limiter or sth?
    thanks so much
    Sep 2016
    sport vs normal - tq limiter, check you have 3 tq maps
    FILE SERVICE
    Oct 2014
    do you know direcctions? i have 4 maps two are flat too low (maybe limo modes) and other two are same values but different dimensions unleast on 500 hpa where are different but on 500 hpa and it doesn´t take in acount.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Last 2 coloms from TQ maps edit this and you have power only in sport mode.
    Regards,
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Oct 2014
    you mean 3549f2 and 354fa8?
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Sedat Garip
    Belgium
    With Kind Regards,
  7. The Following User Says Thank You to sdtsedat For This Useful Post:
    ivanrojo (18th July, 2018)
    Oct 2014
    ok i will try and report thanks you
    Oct 2014
    hello i am still working on that file, someone know which map (nm to iq) is principal one, on the other hand toruqe effizienzmodus are for eco mode or just for light shift?
    BR
