sport vs normal - tq limiter, check you have 3 tq maps
hi all! could someone help me with driving modes on that ecu.
I cant understand which maps change when selecting eco mode or sport, normal mode.
i would like to let remap just on sport mode.
I have tried throttle maps wirh no luck even nm to iq maps and same, maybe lambda maps?
here i let you my .ols maybe cpuld be usefull for someone
could someone take a look if i forget some limiter or sth?
thanks so much
FILE SERVICE
do you know direcctions? i have 4 maps two are flat too low (maybe limo modes) and other two are same values but different dimensions unleast on 500 hpa where are different but on 500 hpa and it doesn´t take in acount.
Last 2 coloms from TQ maps edit this and you have power only in sport mode.
Regards,
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
you mean 3549f2 and 354fa8?
Here
Sedat Garip
Belgium
With Kind Regards,
ivanrojo (18th July, 2018)
ok i will try and report thanks you
hello i am still working on that file, someone know which map (nm to iq) is principal one, on the other hand toruqe effizienzmodus are for eco mode or just for light shift?
BR
