Results 1 to 6 of 6
    Junior Member incognitus4's Avatar
    Nov 2016
    PL
    Default Opel UHP Bluetooth module - not visible
    The UHP is simply not visible by phone (of course "Enable bluetooth" and "UHP Visible" options are selected).
    Also, the "Start searching" option does not work. Nothing happens when it is selected.
    The interesting part is that today I've got a second module with exactly the same problem.
    Both modules are Delphi-Grundig 13187911 (ZJ-ident), updated to 3.20 software. They come from Vectra C and Zafira B.
    Maybe it's some kind of a known issue?
    Any ideas greatly appreciated.
    Feb 2010
    UK East
    if the start searching doesnt show on screen for about 10secs then the unit is faulty...
    by that i mean if you hit start searching and it immediately finishes like it nots even trying then again, faulty unit.. Not been able to resolve this issue.
  3. The Following User Says Thank You to plasma533 For This Useful Post:
    incognitus4 (19th July, 2018)
    Nov 2016
    PL
    Yep, it's not even trying to search.
    Have you tried resoldering the CPU and/or bluetooth module?
    Feb 2010
    UK East
    not tried anything other than a reflash
  6. #5
    Nov 2016
    PL
    also the first thing I tried
    i've got a hotair station somewhere, i'll try it. nothing to loose anyway.
  7. #6
    Nov 2016
    PL
    A proper reballing is here unfeasible so I just heated them a bit.
    Gentle touch gave no results. A bit more heat killed both the units
