Results 1 to 7 of 7
    mexanico1971's Avatar
    portugal
    Default SAAB 9-3 TID PSG16 clone / Swap
    Hi Folks
    I have one Saab 9-3 2.2 TID from 2001 , to make it work , because they swap Pump !
    I have try Carprog and FVDI to read eeprom ,but no luck !
    I open the ECU and see PCB is diferent from Opel comum PSG16
    Any one have BDM pins out for this ECU PCB ?!
    ref
    PCB full
    BDM points
    Or tips to do the job
    Thank"s in advance
    BDM points
    My work is my life ART TECH GARAGE
    May 2016
    Read full mpps v18.
    Bdm pinout for xprog.
  3. The Following User Says Thank You to naprawa5 For This Useful Post:
    mexanico1971 (19th July, 2018)
    carbon7319's Avatar
    Aug 2011
    Macedonia
    And if you know pin , with what tool you will adapt pump on SAAB ?
    portugal
    Quote Originally Posted by naprawa5 View Post
    Read full mpps v18.
    thank"s , but PCB is different
    BRs
    portugal
    Quote Originally Posted by carbon7319 View Post
    This Saab pump is different, is K-line
    Or I clone MPC and eeprom or I use tech2 width server to flash "upgrade" ecu pump
    Brs
    carbon7319's Avatar
    Aug 2011
    Macedonia
    If you use Tech 2 then you do not need any pin.
  8. The Following 2 Users Say Thank You to carbon7319 For This Useful Post:
    mexanico1971 (21st July, 2018), vlaki electric (26th July, 2018)
  9. #7
    portugal
    Any one Tuning the ecu"s ??
