check actual value
eis ewm
and gear position N or P
Hi. From begining. W220 eis w215 type.
Owner came put key . Key not accepted no turnt no start.
Than owner do some work checked modules wiring etc by itself. Dont know exacly what ne did.
That brought eis to me. Tested on bench bad key. New key made key accepted eis unlock etc.
When he put eis in car key accepted ignition comes on but starter not turn. When turn key of and out. Ignition remain on. And 1 tailight is on too.
When disconect battery all goest off untill next key turn.
Anyone familiar with this? Its problem key eis or he messed up something in the car while searching for fault in begining. As he checked sam moduler etc.
I could upload eis dump check for corrupt data
check actual value
eis ewm
Remote job cant check. Owner just called. Car started. Some 12v cable was loose or not connected to sam. Now car starts but when turn key ofc take out car runs with key out he cant stahl it
lock its demage inside
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
Told do same as in that post. Disconnect eis when car runs . Car still running wont stahl
Sam changed probem still here.
can someone check dump for corrupt?
do you tr
to use nec from original key and swap to used good board
No. I was asked to make new key. As job is remote cant check nothing more. In this case i dont think its key problem.
Anyone? Post 8
Than all good ive done on position 7.
Today again news from owner now car not cranks. But ignition ok
Now the first key will work
Dabar veiks ir pirmas raktas
A topic that interests me
drugowaz (22nd July, 2018)
Thanks for support. But in this case this does not do any affect on problem
