    Feb 2018
    Serbia
    Default Zafira pin from UEC
    hi can anyone please help with a pin code from the UEC
    Zafira 1.9dt
    2006
    Essex
    try 5750-Good Luck
  3. The Following 2 Users Say Thank You to squirrelbandy For This Useful Post:
    jgspnovisad (21st July, 2018), Meat-Head (21st July, 2018)
    Feb 2018
    Serbia
    okay,thanks a lot
    It's okay thanksOkay, thanks a lot
    Meat-Head's Avatar
    Sorry to bother you, how did you read the EEPROM?
    i had one for educational or entertainment purposes and ended up destroying the board!
    Feb 2018
    Serbia
    The eeprom is located below the main board connector
    I had to cut off the plastic of the connectors above the eeprom and I got more places to remove the eeprom
    Of course, it is not easy, but it needs to be worked carefully....
  7. The Following User Says Thank You to jgspnovisad For This Useful Post:
    Meat-Head (23rd July, 2018)
  8. #6
    Meat-Head's Avatar
    Thank you, was going to work out solder points but never bothered
