You tested it?
HEX FW 48 available
Chiptuning solutions - dyno proven
I saw on others forum bugs when flash but not tested...
boost turbo (22nd December, 2022)
No, allways wait for DK users to "aprove" before buy..
you can check the difference ktmflash and pcmflash
http://blog.obdexpress.co.uk/2018/06...ite-ford-ecus/
also pcmflash powerbox chines have ktmflash jtag powerbox
moky (30th September, 2018)
Hi all Ive tried to ktm on some old dsg units here and it work ok
But I had to use a genuine tactrix cable
Tactrix clone not work ?
I had one for other software and work very bad.. need to buy official..
users of ktmflash on tricore here? does it work fine?
just ordered one ktmflash, will test on some tricore ecu and send report here soon.
chipcarcordoba2 (1st October, 2018), Col19 (3rd September, 2021), eddieddi (5th October, 2018), kamolsfss (30th March, 2020), norman1967 (30th September, 2018), raskolnikov1975 (23rd May, 2021)
Excellent looking forward to your review
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
moky (1st October, 2018)
As promise i received ktmflash + powerbox tested on edc17C10 and work fine with this tactrix clone.
checksum ok all ok ,read write rapid , excellent
will test GPT and dsg soon but I think will work.
Col19 (3rd September, 2021), kamolsfss (30th March, 2020), norman1967 (20th October, 2018)
Moky
So your tactrix is connected to the rear of the power box?
And then to laptop via the usb?
Just use ktag pinout?
I thought edc17c10 was GPT!
hi yes tactrix connected to the rear of the power box and in front gpt and tricore cable,cable gpt and tricore ktag seems to be ok and help of dimsport or ktag yes
good box
tested on edc17cp14 R/W chk ok
Col19 (3rd September, 2021), kamolsfss (30th March, 2020), norman1967 (21st October, 2018), satriawr (26th January, 2020), Stelaras26 (9th January, 2020)
