Results 1 to 7 of 7
    Default GALETTO V54 0475 PROBLEME
    HELLO
    i don't undestand what appen??
    when i connect my galetto v54 in menu system i can find only port com i dont find galetto v54??
    How i can fix it????
    thnk in advance
    best regard
    Feb 2018
    http://www.fgtechnology.it/Setup.exe,-downloud setup FIRST INSTALATION-go run after don them plug galleto
  3. The Following User Says Thank You to zoki21 For This Useful Post:
    newgeniehex (27th July, 2018)
    Feb 2018
  5. The Following User Says Thank You to zoki21 For This Useful Post:
  6. #4
    HELLO
    thank to all but my galetto is a clone ??it is dangerous for clone?
    i have find the dravers in my clone soft but it don't work i have always port com???
    my galetto it is dead?
    regard
    rob h's Avatar
    May 2011
    Use the software that came with the programmer.
    Make sure that you have the 0475 version!
    Virus scanner off, run as admin.
    You could try onder software, Just to help setup the driver.
    No need to run old program, do IT is safe to use.
  8. The Following User Says Thank You to rob h For This Useful Post:
  9. #6
    Feb 2018
    If you laughing Gallet 0475 setup used for the driver despite the fact that is a clone, I also I have a clone and use that driver
  10. The Following User Says Thank You to zoki21 For This Useful Post:
  11. #7
    Feb 2018
    fork fine,no problemo
