Results 1 to 12 of 12
    Jan 2018
    Default Airbag Dacia spc560
    i need clear file
    airbag a2c85839702
    985102122r
    read data with xprog 5.55
    hudy26's Avatar
    May 2017
    Default ok
    test and give a report
    Jan 2018
    Will work?
    hudy26's Avatar
    May 2017
    Yes work Perfect
  5. The Following User Says Thank You to hudy26 For This Useful Post:
    carlitros (13th November, 2018)
    Jan 2018
    not work hudy26...
    Jan 2018
    Is there anyone?
    hudy26's Avatar
    May 2017
    Works perfectly. You just have to press thank you and reputation
    Jan 2018
    file hudy26 has no changes
  10. #9
    hudy26's Avatar
    May 2017
    I'm sorry I did not check you have a bad reading to correct it
  11. #10
    Dec 2014
    LOCATING
    try this file.... will work.
  12. The Following User Says Thank You to sanjeev For This Useful Post:
    carlitros (23rd December, 2018)
  13. #11
    hudy26's Avatar
    May 2017
    http://www.digital-kaos.co.uk/forums...5839702-spc560
    Here you have the correct file read out of your sensor
  14. #12
    Jan 2018
    solved...work...file xprog
  15. The Following 2 Users Say Thank You to Dijagdijag For This Useful Post:
    kimodiag (15th October, 2018), rtv (2nd February, 2019)
