Results 1 to 5 of 5
    Jan 2009
    Default bmw ews II ics reading
    Anyone manage to read ICS with upausb? Very hard to solder mcu after removed
    Romania
    Quote Originally Posted by ziko View Post
    Hello , you can remove MCU and after you need to solder a socket for that device .The middle of socket you need to broke and in this way you have access to pins for soldering , after you manually put back MCU . But with xprog you sholud be able to read on board .
    Jan 2009
    Other ews I read ics with upausb,this one cant,I lift,rst,rx,tx...
    Romania
    Xprog you need , or oLD Xprog for hc11 mcu , and this i never succesed to read on board , try to remove and connect xtal and solder wiring on mcu
    Jan 2009
    Thanks for trying help , I read mcu in socket with upausb, no problem for me to read mcu, but this is hard to solder and I wanna read ICS like other ews 2,3 ...
