Results 1 to 6 of 6
    Dunker's Avatar
    Yorkshire
    115
    Downloads
    4
    Uploads
    Default Corsa D BCM Help reading NEC with UPA
    As the title. Has anyon got any tips for reading the NEC. The board type is as in the picture.
    On UPA-S I have FLMD0 on pin 8. Is this PDX as in the picture.
    Do I read it with 3 wire or UART (and forget OSC).
    Also on mine I have a 8 pin smd chip just under where it says RXD on the pic.
    The reason I ask is it wont read, RXD is low. Soldering looks ok.
    Is this one the uPD70F3632.
    Sorry to be a dick.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Bllinda's Avatar
    May 2010
    Baltic
    192
    Downloads
    89
    Uploads
    5
    Default uart.3-vire
    Try .... ....
    I have a topic in the forum
    Mercedes IR F82B-05E6-G72G
    Mercedes IRCL or IFZ (7)05B16-F62J
    I can not find a damp virgin CIM (
    delphi MCU1 (TOP) 908AZ60 1J35D, 4J74Y)
    Can YOU help me after I helped you?
  3. The Following User Says Thank You to Bllinda For This Useful Post:
    Dunker (7th August, 2018)
    Dunker's Avatar
    Yorkshire
    115
    Downloads
    4
    Uploads
    Thanks for that. As I assumed with the pinout.
    Still no change with it as it was.
    I removed the SMD 8pin IC just under the RXD connection and it gets the device ID so the SMD must have been pulling RXD low.
    This is what I get now:
    Device ID: 10 7F 04 61 7F 7F 7F 97 80 80 80 80 02 7F 7F 01 02 C4 37 B0 46 B3 B3 37 B9 20 20 7F FF 00 00 00
    Firmware Version: 03 01 00 02 00 01
    Device not Respond
    Parameter error
    Reading: 2 Errors Found Device: uPD70F3632 Range: 0 - FFFF
    This is in UART mode. Cant get anything in 3 wire mode.
    I get same result with uPD70F3379 and uPD70F3632
    Any ideas?
    Dunker's Avatar
    Yorkshire
    115
    Downloads
    4
    Uploads
    I can see now the device is uPD70F3379. The 'B' prefixs threw me for a second but I can see that the highest bit is for odd parity nearly all way thru the ID. Doh. Has to be summat simple.
    Ill go out for a curry and sink a gallon tonight and think about it tomorrow.
  6. #5
    Dunker's Avatar
    Yorkshire
    115
    Downloads
    4
    Uploads
    Thought it would be a simple mistake. Put my NOVA 2400 on it and frequency from BCM was 5MHz. Built a 4MHz clock generator and fed that in to the BCM and bingo. Read like a charm. Looks like either NEC key is corrupt or crypted pin in 93c86 is corrupt. My guess is the eeprom. Ill compare a few dumps from here over weekend and see whats what.
  7. #6
    Bllinda's Avatar
    May 2010
    Baltic
    192
    Downloads
    89
    Uploads
    5
    Now, as you read NEC MCU can do as you want.
