Results 1 to 9 of 9
    Jun 2013
    Default Renault reprog mgi/vdo
    Hallo
    I need cd with Soft to reprog mgi/vdo
    Renault espace 2.0t 2002 sagem s2000
    Thanks for help
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Have a look into your box, but for sure you can't do reprog because CLIP will ask you the technical definition code. This must be asked to Renault techline.
    You can try to ask to delltrotter how he solved the same problem.
    Greetings,
  3. The Following User Says Thank You to Louislesinge For This Useful Post:
    wbart (8th August, 2018)
    Jun 2013
    I have calc code
    Jun 2017
    French Jungle
    Ok,
    But this not the usual way to reprogram. When you'll pass the first operation CLIP will ask you one more thing...
    Jun 2013
    I have a problem , when i click reprog by cdrom , clip writing error 107 - unknown number ecu
    my ecu 8200285232
    8200279458
    Member Flisting's Avatar
    Dec 2012
    Someone can share this cd ? Thanks for help
    Hi. Do you solved problem?
    Quote Originally Posted by wbart View Post
    my ecu 8200285232
    8200279458
    Well, anyone resolve this problem?
    I have too error 107 when trying reprog S2000 after actuator replace.
  10. #9
    HeXeN's Avatar
    Mar 2015
    here link for CD. but it never worked for me... f..k this car. you can do reprog only with s3000.
