Hello everybody,
i need some help for get immo off on my multistrada.
If someone can help me. It will be very nice for me.
Thank you
Hello everybody,
Thank you
Nobody can help me?? please!!!
be patient
Thank you so much for the help i will try this week end. i tell you soon if it's work
guys info from beginner ......
on ducati l immo is in the dashboard if I'm not wrong .....
if I do immo off su ecu the ecu does not ask immo to the dashboard so the bike starts or how does it work ???
thank you.....
ps
the solution of dtc748 is good???
joker01 (12th August, 2018)
i have same problem IAW5AM from multistrada
need immo off
this program has performed an illegal operation and will be shut down
with this eep memory you can virginiz or make red key, but not immo off
for immo off other memory 320ko
Chupsy (30th June, 2021)
Thank you for answer,
i read now with kess and i hope that is okay
your file off
but your file is for Monster 620 not multistrada
tonynet5 (27th September, 2021)
hi I noticed that you have helped many users with the removal of the immobilizer.
I would like to ask you if you are kind enough to help me in removing the immobilizer too
I would be really grateful
I thank you in advance
you can help me for ducati 100 please ???
Check here for XDF for your ECU. https://ecu-repo.spiro-media.de/. Use it in tunerpro.
You could flash a bin which is Ducati Performance without immo or some of the XDF have immo off switch defined.
