For total remove gel you have to use:
- ultrasound tab
- solvente remover for pulyurethane gel
does anyone here repair these ABS ECUs? I have one ECU with interrupted wires inside. Is it possible to chemically remove that nasty gel from the plate?
IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
- ultrasound tab
raceshadow (16th August, 2018)
too easy repair this ABS module. similar to simtec 71
Wire bounding repair machine is important for good job.r last
Can be soldered under a microscope.
Remove all aluminum tracks and solder.
I do this as in the photo. (example BMW E65)
Im from Belarus Brest
