Ok I try to Read and post file
Bdmjoe (9th August, 2018)
Hi, sv2hqx, I read the eprom , and post here, I need 11500kms, is possible
eprom24c04-ic401.rar
here is your file
hi, the bike year is november 2014 model pcx 125
thanks very much
Hi, members I can`t dowland file attached, where is the problem?
Hi, Nicks and another members, I have problem with this dashboard on Honda pcx I try in road this weeks, two times , when starts engine , displays works good but when rpm going up the display not work, I cheek connections and resolded IC eeprom but are good and flat cable connection.
I need help
I possible the bad file
One question about pcx dashboard, the kms are stored in another Ecu, for sample engine Ecu,
Hi. I neead 15800 pleace. THX
dash the same as the author of the photo thread, memory 24C04. The current indication is 29 thousand
When requesting help from Kaos Members,please provide some details like :
1. Year,Make,Model of Vehicle.
2. Eeeprom/MCU Type/ Any other Dash details
3. What you did to the vehicle.
4. What equipment you did it with.
5. Post up original/adjusted files
6. Original Mileage
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
