2012 Chevy Silverado
13578408
95320
help clear dump.
i try to erase with scan tool. deployment command stay. can not erase. plus other DTC's like curtains,..
13578408
95320
help clear dump.
DON'T JUST SAY PRESS IT.....
Check this ...
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
compucriss (24th October, 2019)
i still get DTC's, deployment command, and many more DTC's all airbags and seat belts.
i have a donor module here for silverado. i install.. only get the one dtc the setup config.
i dont have MDI to config donor module.
so what i did next is , write dump dragon made me , install to donor module same thing all DTC's with donor module.
so its the dump. that is bad. any way to fix ?
hi friends can you help me read the eeprom 95320 that someone brings will have the pin out to read i'm using upa-s thanks
