Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 73
  1. #31
    jodge's Avatar
    Mar 2017
    yeah but cover some plastic, tape or something it will scratch the car.
    @super-jumbe i just opened recently a 2015 Ford Focus with rod. The only lock is partially damaged and the only key is in the trunk. 2 min job. In this case you have more options than lishi. If the key is keyless (like mine) you can push the start button with the rod and after the center switch or simply pull the door handle
    I like the lishi but i like more my time
  2. The Following 2 Users Say Thank You to jodge For This Useful Post:
    doctore (13th August, 2018), PocketHero (14th August, 2018)
  3. #32
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Maybe anyone has gathered some info by particular car. I mean unlocking methods?
    I saw online dvd and books . Maybe you have in pdf or video formats.
    Or any other interesting usefull info about emergency car unlocking,good tips,tricks etc
  4. #33
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by drugowaz View Post
    Everything depends on the car. When it is 'Merican then it is easy to open, becuse the FBI guys don't use Lishi.
    When it is French or Italian, mostly the same, no deadlock.
    For everything else call Mr. Lee ;-)
  5. The Following User Says Thank You to PocketHero For This Useful Post:
    drugowaz (18th August, 2018)
  6. #34
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Is here anyone good in decoding locks with lishi?
    I need some advice-info to what directions need to decode wafers after lock is picked.
    I will do some photos on lishi with arrows you just by numbers tell up or dows,to or from engraved number on lishi.
    Asking because watched some videos and i see diferent lock is decodd to diferent side. If somebody can advice write me pm
    Example same lock decoding to oposite directions.
    One video onwards egraved number other video from it. This i do t get it
    https://youtu.be/ICygHk7d_8c
    https://youtu.be/pHUN7RCAA9Q
  7. #35
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Example lock i have
    Hu92
    If decoding to direction of engraved number i have 32212221 if oposite direction 13123332
  8. #36
    Junior Member Akslock's Avatar
    Feb 2018
    Example lock i have
    Hu92
    Depends if tool is single lifter or double lifter. If single lifter opposite, double lifter same direction( on hu92).
    Sent from my SM-G892A using Tapatalk
  9. #37
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Oh got it. Mine is single
    Its same for all decoding 1 or 2 lifterss?
    In video cy24 losk. Its single lifter and they decoding to opposite directions :/
  10. #38
    Dec 2010
    Nottingham
    its really very simple to know which way to decode with each tool .
    for decoding the tools are broken down into just 3 catagories ,
    1) edge key tools ( for edge key locks )
    2) single lifter high security/ laser track tools
    3) multiple lifter high security/laser track tools , ie , 2 and 4 lifter laser track tools
    so as a general rule to know which way to decode with a 2in1 or 3 in1 tool ;
    1) edge key tools 1 and 2 lifter regardless all decode in the same direction as the lock is picked
    2) single lifter laser track tools all decode in the opposite direction to picked
    3) twin and quad lifter laser track tools all decode in the same direction as picked
    it is that simple to know which way to decode with your tool , or if you prefer , to simplify further , all single lifter laser track tools decode in opposite direction , all other tools in same way as you picked .
  11. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    drugowaz (20th August, 2018), subfan (9th September, 2018)
  12. #39
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This is i needed. Thank you very much!
  13. #40
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Playing with hu100 lock+key from china.
    Key turn ok. But with lishi t8 cant open it.
    All wafers is pulshed to cut no1 but it still wont turn try release tension etc beu wafers droping and need start from beggining.
    Update after 2 hours finished open
  14. #41
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Can anyone from experience write to which direction lock is opened after picked on euro-usa cars to left (car front) or right (trunk side)
    Vag-left
    Bmw-left
    Honda-right
    Mercedes-
    Toyota-
    Lexus-
    Nissan-
    Chrysler didge jeep-
    Kia-
    PSA cars-
    Ford-
    Hyundai-
    Fiat alfa lancia-
    Mazda-
    Opel-GM-
    Other questuon about pick diference to lock or unlock position. Im noticed that theres huge diference to open lock to lock position. S
    Now playing few hu64 one lock i can pick to any direction 20-40seconds. Cls 2007
    Other hu64 i only can open to lock position fairly easy. But to open to unlock position can not go. Total maybe half day still cant open.
    Is there any tips on this?
  15. #42
    doctore's Avatar
    Nov 2015
    Colorado Denver
    just joke
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  16. #43
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This i will use to. Cars valued under 500euro
  17. #44
    camelgd's Avatar
    Jan 2011
    South Illinois
    Toyota/Lexus to trunk side (Clockwise)
    Chrysler with vertical button to front (Counterclockwise)
    Chrysler horizontal button to rear (CW)
    GM to front CCW on most 4 door
    Many variations after that, I use Steve Young's car opening book for general information on direction to pick.
    As far as ease of picking, GM laser, Nissan and Toyota all seem to pick easier to locked position. Personal opinion on that.
  18. The Following User Says Thank You to camelgd For This Useful Post:
    drugowaz (6th September, 2018)
  19. #45
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Maybe i overlearned lately one day i open lock in 20 sec. After few days i cant open SAME LOCK at all.
    Today free time on hu92 my car. I was able to unlock it best time in 9-30sec . A week or two ago. Today triend again couldn open it at all this killing me.
    Last vag hu66 with lishi in rush 5 min couldn open,lost patience took inner groove pick opened in 10sec.
    I think if one day get skilled on one lock .later take other type locks you loose skill on previous lock open in same time.
    Can anyone tell me what is mid door open time with lishi? Anyone pickingnit 10-20mins?
    I watched multiply videos. Time 30sec upto 2 min.
