Page 1 of 5 12345 LastLast
Results 1 to 15 of 73
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Emergency car open kits
    Hi. Is there any similar kits for same price in europe? Or usa but with deliveri to EU
    https://www.accesstoolsusa.com/mobil...oductCode=SPRO
    Dec 2010
    Nottingham
    hickleys and tradelocks both sell access tools equipment in uk
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    drugowaz (12th August, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Tradelocks online i dont see such kits.hickleys found. Thanks
    jodge's Avatar
    Mar 2017
    lockdercoders too, great stuff i use it
  6. The Following User Says Thank You to jodge For This Useful Post:
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I see 2 kits there. Small ones. Its enough pieces fir full work on all cars?
  8. #6
    Dec 2010
    Nottingham
    nothing beats lishi for entry and of course lishi can open the car when it is deadlocked unlike rods . i have access tools wire rods on van just a set of 3 and a lasso tool , but i cant remember when i last used one , literally must be years as no use on a deadlocked vehicle
  9. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    drugowaz (12th August, 2018), super jumbe (12th August, 2018)
  10. #7
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Yeah lishi thats all clear. I like them very much. But loocking for say prety mutch universal kit . Guess no need but full kit for 300 400 as from photos i see its mainly for old cars .as you mention no deadlock.
    Say car is deadlock and lock is damaged or stuck,lishi not help.
    What then? You drill cylinders out?
  11. #8
    rob h's Avatar
    May 2011
    If lishi fails on a door try trunk.
    Clean the locks, and almost all will open this way.
    2 large pump bags, and a few reach tools is all that you need in a universal set.
    Pulling the door handle inside and outside the car at the same time. Works on some cars.
    Pulling out the rear window. Always a good clean way.
    Most are clamped in the rolling mechanisme, and slide out when strongly pulled upwards.
    You need to jimmy the window outside of the door rubbers first.
  12. The Following 2 Users Say Thank You to rob h For This Useful Post:
    doctore (12th August, 2018), drugowaz (12th August, 2018)
  13. #9
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Ok got it
    But on some cars theres only 1 lock in door.
    Say f series bmw.
    Car for sure deadlock. No push button inside help. Access to trunk not possible. And say cylinder is damaged and not possible to open. What you do than?
  14. #10
    rob h's Avatar
    May 2011
    If they can buy a F-series BMW, they can affort a new window.
    Just put tape over the cheapest window, and break it.
    Then get the cas4 and ecu, and learn key.
  15. The Following 2 Users Say Thank You to rob h For This Useful Post:
    doctore (12th August, 2018), hcip (13th August, 2018)
  16. #11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Basicaly not long time ago rad about bmw here somewhere on dk .that car was locked. Later took out cas etc made key but it didnt worked as not accepted like some safe mode when car was locked with remote.
    Is there any models like if you lock it with remote.and access to car not opening the door try to start it ir wont go?
  17. #12
    rob h's Avatar
    May 2011
    I am pretty sure that a correct programmed key, will work.
    Even when the alarm whas activated.
    The key, created is a dealer key, that needs to be placed near the steering colom to be recognized and accepted.
    This should not be a problem.
    Ford, i believe they have something like this. Or Fiat with alarm.
    Not BMW
  18. The Following 2 Users Say Thank You to rob h For This Useful Post:
  19. #13
    Moderator
    PremierD's Avatar
    Jun 2009
    Automatic center punch .. opens most vehicles mate
  20. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    doctore (12th August, 2018), super jumbe (12th August, 2018)
  21. #14
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by rob h View Post
    Shame! In such cases mostly the owner has the key, but can't open the door
    Pump away the door
    Put the key into the hole, or place the smart one on the steering wheel
    Push the key or start button.
    Deadlock opens
    Pull the internal door handle and its open
  22. #15
    drugowaz's Avatar
    Mar 2015
    Lithuania
    In keys lost this not help i guess
    If key present its other case. You can maneuver.
