RE CODING CITROEN C5 USED REMOTES / TRANSPONDERS
Results 1 to 4 of 4
    Feb 2016
    Default RE CODING CITROEN C5 USED REMOTES / TRANSPONDERS
    GOOD DAYS, I HAVE A CONSULTATION TO SEE IF YOU CAN HELP ME. I HAVE THE CASE OF A CITROEN C5 WHICH HAS THE FOLDED 3-BUTTONED FOLDING KEY. I NEED TO MAKE A KEY COPY WITH COMMAND, BUT I KNOW THAT THIS MODEL TAKES TRANSPONDER PAIRING AND REMOTE INFORMATION. I HAVE TRIED TO GENERATE WITH THE APPLICATION KD X2, BUT ONLY I GENERATE THE REMOTE, SO WHEN I DO NOT TRANSPOND, IT DOES NOT LET ME CODIFF. DO YOU KNOW ANY WAY OR WHAT KIND OF INFO DO WE HAVE TO VOLCATE TO THE TRANSPONDER SO THAT THE REMOTE CAN BE CODED? THANKS IN ADVANCE.
    Feb 2016
    I post the content of a blank new key, for check the similarities in new virgin and remote transponder status.
    TRANSPONDER
    Feb 2016
    and REMOTE info, all buttons:
    Jul 2014
    Sofia
    Your remote info is not correct. It should be exactly 20 bytes last 10 the same as first 10 like this
    5AAA0F4D2D582808E1A4
    If you have new blank key just pair it to car with Lexia/PP2000 and you'll have spare key
