maybe emulator its too old probably hc11 motorola inside ecu
see pictures from ecu before you goo
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
jodge (14th August, 2018)
can you check the pic?
thx
Sir, are you classified as human? Negative, I am a meat popsicle
yeah, it's possible and easy with Julie or OF68 emulator.
Yep its hc11 i tr to read with xprog and lift pin and nothing
For this tipe ecu you need virgin file and mb star if you can read, emulator not work
I tr many time and nothing
And best chose give up from this only can have problems nothing more
jodge (15th August, 2018)
this must be ECU with one plug, here need to put only emulator and cut wires from green and red lamp or remove module.
...problems are with those with 4 or 5 plugs, I also tryed and succeded to make it virgin and personalise to other used immo, with emulators not working.
@Scmortz did you tried julie? I saw in the supported list but who knows.. as doctore says
yepp just one plug fixed with a philips screw
I tryed on W202 with OF68 which is copy of Julie and working like a charm
HeXeN (3rd September, 2020)
deal
thx
doctore (15th August, 2018)
