Results 1 to 3 of 3
    Top Poster zapdus's Avatar
    Jan 2017
    Default Peugeot 307 1.6 HDI damaged ecu swap
    I have Peugeot 307 1.6 HDI 110
    Old ecu was 0281 011 803
    New ecu is 0281 011 863
    Before ecu swap car was fine in LIMP mode with DPF fault
    Removed DPF, checked EGR and now has blank plate
    I have few DTCs, I will try another EGR solutions
    P0104 related to MAF
    P1728 can engine torque implausible (maybee related to EGR solution)
    P1166 rail pressure
    P1113
    P1639
    The car is now having problems when decreasing RPM I can ear noise coming from rail
    Sometimes when acelerating the car shuts off (like in this video)
    BDM files from old and new ecu attached
    Also OBD read from old ecu
    I think BDM read file from old ecu is corrupted (failed to write OBD)
    Dec 2017
    TÜRKİYE
    did you solve this problem
    alclot's Avatar
    Melee Island
    hi mate. I have same situation. Did you fix it?
    Tghanks
