Hi friends,
Pleas i need DPF+ADBLEU off
peugeot 308 ecu EDC17C60
Tank in advance
Hi friends,
Tank in advance
Team dz (7th November, 2018)
Hi, can be done.
We can help on these edc17c60 ecu's with adblue dpf egr dtc off.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
if not solved I have solison this ecu .
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
How did You finally reset the UREA warrning ?
Je le fais via WinOLS
Manuellement !
# Algerian #
