Team dz (7th November, 2018)
Hi, can be done.
We can help on these edc17c60 ecu's with adblue dpf egr dtc off.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
if not solved I have solison this ecu .
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
How did You finally reset the UREA warrning ?
Je le fais via WinOLS
Manuellement !
# Algerian #
